Advancements in Driver Safety: HANS Devices and the SCHROTH SHR FLEX
HANS Devices, Frontal Head Restraints, and the SCHROTH SHR FLEX​
  • Conclusion and Introduction:
    • In the world of motorsport, protecting a driver’s head and neck during high-speed crashes is paramount. Over the years, the introduction of HANS devices (Head and Neck Support) has revolutionized driver safety, becoming the gold standard in frontal head restraint (FHR) technology. These devices significantly reduce the risk of severe neck and head injuries during crashes by limiting head movement and preventing dangerous impacts that could lead to fractures or cervical spine damage.
    • However, as motorsport continues to evolve, so does the technology aimed at enhancing driver safety. SCHROTH SHR FLEX, an award-winning FHR system, has emerged as a competitive alternative, offering advanced features that prioritize safety, comfort, and ease of use. The SHR FLEX incorporates innovative elements like a floating tether, angle-independent collar, and flexible, molded padding, providing drivers with better adaptability, comfort, and enhanced protection.
    • This article will discuss the history and development of HANS devices and frontal head restraints, and then provide an in-depth analysis of the SCHROTH SHR FLEX, exploring its design, features, and benefits for motorsport drivers.
The History of the HANS Device and Frontal Head Restraints (FHR)​
  • Origins of the HANS Device:
    • The HANS (Head and Neck Support) device was developed in the early 1980s by Dr. Robert Hubbard, a professor of biomechanics at Michigan State University.
    • Dr. Hubbard was motivated by the rising number of fatal neck and head injuries in motorsport, particularly in NASCAR, Formula 1, and sports car racing.
    • The primary goal of the HANS device was to reduce the violent forces transmitted to the neck during high-speed crashes, preventing life-threatening injuries.
  • The HANS Device's Early Adoption:
    • After years of research, prototyping, and testing, the HANS device faced initial resistance from drivers and manufacturers, primarily due to concerns over comfort and restriction of head movement.
    • Over time, the device gained traction, and by the early 2000s, it became mandatory in several racing series, including Formula 1 and NASCAR, following extensive safety advocacy and real-world crash data supporting its effectiveness.
  • Functionality of the HANS Device:
    • The HANS device works by attaching to the driver’s helmet and connecting to the seat via straps. During a crash, it limits head movement and reduces the potential for dangerous head and neck angles that could lead to severe injury.
    • It helps prevent basilar skull fractures and cervical spine injuries by keeping the head and neck aligned with the body during impacts.
  • Regulations and Widespread Adoption:
    • As the HANS device proved to be effective in reducing injuries, it became the gold standard in motorsport safety and was mandated by the FIA (Fédération Internationale de l'Automobile) for many international motorsport events.
    • The HANS device is now a key component of the safety gear used in Formula 1, NASCAR, and other high-level racing series.
  • Development of Other FHRs (Frontal Head Restraints):
    • As awareness of head and neck safety grew, several manufacturers began developing alternative FHRs to compete with the HANS device.
    • These alternatives focused on providing similar levels of protection but with additional benefits such as increased comfort, reduced weight, and greater compatibility with various seating positions and car types.
The SCHROTH SHR FLEX Frontal Head Restraint​
  • Overview of SHR FLEX:
    • The SCHROTH SHR FLEX is an advanced, award-winning frontal head restraint system that aims to offer superior safety and comfort for modern motorsport drivers.
    • Designed to address common issues with traditional FHR systems, the SHR FLEX incorporates innovative features that enhance usability and protection without compromising on comfort or flexibility.
  • Key Features of the SHR FLEX:
    • Simple Sizing:
      • The SHR FLEX comes in two sizes: Medium (for necks up to 16 1/2") and Large.
      • The sizing system is straightforward and ensures a comfortable fit for most drivers. The large size can be used by drivers with a smaller neck for extra collarbone space.
    • Angle-Independent Collar:
      • The low-profile collar of the SHR FLEX works with any seat angle and does not interfere with the seatback, making it adaptable to various vehicle setups.
      • The collar rises during impact, automatically adjusting to the optimal tether angle for maximum head and neck protection.
    • Load-Controlled Bump Stop:
      • The SHR FLEX is equipped with a unique bump stop system that helps smooth out the initial tether loading during a collision.
      • This feature ensures that the forces exerted on the driver’s neck are properly managed, reducing the risk of injury.
    • Floating Tether:
      • The floating tether system allows the driver full range of motion for lateral head movement, providing stability during both straight and cornering moments.
      • While allowing side-to-side motion, the tether maintains sufficient support for the driver’s head during impacts.
    • Flexible Legs with Molded Padding:
      • The SHR FLEX features flexible legs with molded padding, eliminating the need for additional pads that could interfere with the seatbelt fit.
      • This design ensures a tight, secure fit of the restraint under the seatbelts, preventing any movement of the FHR during a crash.
    • Retention Ears:
      • The extended vertical ears at the outside edge of the collar help to keep the seatbelts securely in place on the SHR FLEX, even during secondary impacts.
      • This ensures that the device remains firmly in position, offering continuous protection.
    • FLEX Helmet Posts:
      • The SHR FLEX includes helmet posts that mount directly to the M6 nut in the driver’s helmet, ensuring a secure and stable connection between the FHR and the helmet.
  • Benefits of the SHR FLEX:
    • Comfort and Fit: The SHR FLEX’s design prioritizes comfort, offering flexible components and a minimalistic structure that doesn’t impede the driver’s movement.
    • Versatility: The angle-independent collar and floating tether make it highly adaptable to different seat positions and vehicle types, catering to drivers who race in multiple cars.
    • High Safety Performance: With its load-controlling bump stop, flexible legs, and retention ears, the SHR FLEX provides superior safety performance, ensuring the driver’s protection without sacrificing comfort or functionality.
Adam G
Adam G
Owner & Operator of GTWerks
Back
Top
