The Porsche 991.2 GT3 RS is an iconic performance car, and its interior is a blend of high-performance materials designed to withstand the rigors of motorsport while providing a luxurious yet functional aesthetic. The seats, in particular, feature a combination of carbon fiber backing, Alcantara inserts, and leather inserts, each of which requires specific care and attention when cleaning to maintain both appearance and integrity. In this article, I’ll explore the material properties of each of these surfaces, suitable cleaning agents, and methods for safely and effectively cleaning your GT3 RS seats.
Material Properties and Cleaning Considerations
1. Carbon Fiber Backing
The seat structure of the 991.2 GT3 RS incorporates carbon fiber, a high-strength, lightweight material that is both durable and highly resistant to wear and tear. However, carbon fiber requires gentle care to avoid scratches or damage to its delicate surface.Key Properties:
- Lightweight, high-strength material
- Resistant to corrosion and staining
- Prone to scratches and abrasions
- Use a microfiber cloth to gently wipe down the surface.
- If needed, lightly dampen the cloth with water or a mild, pH-neutral cleaner.
- For heavy cleaning, use a specialized carbon fiber cleaner designed for automotive interiors.
- Avoid using cleaners that are too acidic or alkaline, as they may degrade the resin or finish. Always test a cleaner in an inconspicuous area first.
2. Alcantara Inserts
Alcantara is a high-performance synthetic material commonly used in automotive interiors, including in the 991.2 GT3 RS seats. It mimics the appearance and feel of suede but is far more durable and resistant to wear.Key Properties:
- Soft, suede-like texture
- Breathable and moisture-wicking
- Sensitive to excessive moisture and oils
- Requires gentle cleaning methods
One effective product for cleaning Alcantara is AMMO Shag Fabric Cleaner, designed specifically for this material as well as for Porsche Race-Tex and fabric surfaces. Here's a closer look at how to safely use this cleaner.
Using AMMO Shag Fabric Cleaner for Alcantara
AMMO Shag Fabric Cleaner is a powerful yet gentle cleaner designed to lift dirt and grime from Alcantara without damaging its fibers. Here's how to use it effectively:Ingredients:
- Water: Main solvent, making up more than 50% of the formula.
- 2-Butoxyethanol: A mild solvent that helps dissolve oils and grease (1-5% concentration).
- Tetrasodium EDTA: A chelating agent that binds to minerals and helps break down dirt (1-5% concentration).
- Alcohols, C9-11 ethoxylated: Surfactants to lift and suspend dirt (1-5% concentration).
- pH: 10.0–11.0, making it slightly alkaline, but safe for fabrics like Alcantara.
- Pre-test: Always test the cleaner on an inconspicuous spot to ensure it does not discolor or damage the material.
- Application: Spray AMMO Shag liberally onto the Alcantara surface. Allow it to sit for 20-30 seconds to penetrate and lift dirt.
- Agitation: Using a soft upholstery brush or a scrub pad, gently agitate soiled areas to lift dirt from the fibers.
- Wipe: Use a clean microfiber towel to remove the lifted dirt and cleaner. For best results, you can also use a wet vac to extract excess cleaner and dirt.
- Drying: Allow the Alcantara to air dry naturally. Avoid direct sunlight or heat sources.
3. Leather Inserts: Cleaning and Conditioning
Leather is another premium material used in the 991.2 GT3 RS’s seats. It provides a luxurious look and feel but requires maintenance to keep it soft, supple, and looking fresh. Leather can suffer from wear, UV damage, and staining if not cleaned and protected properly.Key Properties:
- Durable, flexible, and soft
- Susceptible to staining from oils, dirt, and UV rays
- Requires conditioning to maintain suppleness and prevent cracking
Using AMMO Lather Interior Cleanser for Leather
AMMO Lather is a gentle foaming cleanser designed for leather and vinyl. It cleans effectively without stripping oils or causing the material to dry out.Ingredients:
- Water: Solvent base (main ingredient).
- Polyethylene Glycol: A mild surfactant for dirt and oil removal (1-5% concentration).
- Quaternary Ammonium Compounds (Coco Alkyl): Mild cleaning agents that help emulsify dirt without damaging leather (concentration not specified).
- pH: 6.5–8.5, making it safe for leather and vinyl.
- Pre-test: Always test Lather on a hidden spot to ensure compatibility with your leather.
- Spray: Spray Lather directly onto the leather surface or onto a clean microfiber towel.
- Scrub: Use a soft-bristled brush or microfiber towel to gently clean the leather. If necessary, use gentle circular motions to lift dirt from the surface.
- Wipe: Wipe away the dirt and excess product with a clean microfiber towel. Do not let Lather dry on the surface.
- Protection: After cleaning, consider applying AMMO Mousse to condition and protect the leather, preventing UV damage and keeping the material supple.
Final Thoughts
Caring for the seats in your 991.2 GT3 RS requires a thoughtful approach, especially when dealing with materials like carbon fiber, Alcantara, and leather. For each material, it’s important to use appropriate cleaning agents and methods:- Carbon Fiber: Wipe down with a microfiber cloth, and avoid harsh chemicals.
- Alcantara: Use a gentle cleaner like AMMO Shag, along with a soft brush to maintain texture and appearance.
- Leather: Clean with AMMO Lather and condition with AMMO Mousse to preserve the material’s softness and protect it from UV damage.
