Michelin Pilot Sport Cup 2 R vs. Goodyear Eagle F1 SuperSport RS vs. Pirelli P Zero Trofeo R: Ultimate Track Tire Showdown
Conclusions:
  • For Best Lap Time (Dry Conditions):
    • Michelin Pilot Sport Cup 2 R is the top choice followed by the Goodyear Eagle F1 SuperSport RS.
  • For Control & Fun:
    • The Pirelli P Zero Trofeo R.
  • Wet Conditions:
    • Pirelli is the better choice however be aware of the rear-end aquaplaning.
  • OE vs. Aftermarket:
    • OE tires (Michelin and Goodyear) are designed for predictability and safe handling, making them ideal for track-day enthusiasts who value stability. Aftermarket tires (Pirelli) provide higher performance in the wet, and provide consistent dry lap performance.
Key Themes and Findings:
Overview:
This review compares three high-performance track tires: Michelin Pilot Sport Cup 2 R, Goodyear Eagle F1 SuperSport RS, and Pirelli P Zero Trofeo R. Tested at Michelin's France facility using a Porsche 911 GT3 RS, the evaluation focused on wet handling, wet braking, dry handling, and dry braking, with an emphasis on dry track performance.
OE vs. Aftermarket:
  • Michelin and Goodyear are OE (Original Equipment) homologated tires, co-developed with Porsche for the 911 GT3 RS.
    • Key Insight: OE tires are generally more predictable and offer safer handling, especially for less experienced drivers.
  • Pirelli, an aftermarket tire, offers a more direct driving feel with quicker turn-in, but at the expense of increased rear-end instability, making it more challenging to manage in certain conditions.
    • Key Insight: Aftermarket tires like the Pirelli are more performance-oriented but can be less forgiving.
Performance Breakdown:
Wet Performance:
  • Goodyear Eagle F1 SuperSport RS:
    • Displays significant front-end aquaplaning, leading to understeer. It provides moderate low-speed grip.
    • Quote: "The car is very understeery as the front end aquaplanes first by quite a long way."
  • Michelin Pilot Sport Cup 2 R:
    • Similar in balance to Goodyear but slightly better aquaplaning resistance and more mechanical grip at low speeds.
    • Quote: "It didn’t aquaplane at the front quite as early."
  • Pirelli P Zero Trofeo R:
    • Exhibits superior wet handling, better aquaplaning resistance, and increased mechanical grip. However, it can cause rear-end aquaplaning, leading to oversteer.
    • Wet Performance Winner: The Pirelli stands out for its wet handling capabilities and is significantly faster than both Michelin and Goodyear in wet conditions.
    • Quote: "The extra mechanical grip this tire does have means it's almost seven seconds quicker than the Michelin."
Dry Performance:
    • Outstanding grip, especially in braking (1.4g). It is well-balanced, with a slight first-lap advantage due to its aggressive performance characteristics.
    • Quote: "The grip is outstanding... the most insane braking you've ever come across on a tire."
    • Matches Michelin’s first-lap pace, but its performance drops off quicker over subsequent laps. Feels more race-focused, like a slick tire with grooves. However, it tends to exhibit more understeer than the Michelin.
    • Quote: "It felt meatier, manlier... it just felt more poised to race."
    • Slower in dry conditions compared to Michelin and Goodyear but provides a more manageable and predictable feel. It is less aggressive, offering consistent performance with minimal drop-off across multiple laps. Ideal for less experienced drivers.
    • Quote: "It felt like it could go on all day... the most manageable tire."
    • Dry Performance Summary:
      • Michelin offers the best outright lap time in dry conditions.
      • Goodyear performs similarly to Michelin but loses pace after the first lap.
      • Pirelli lags in terms of speed but stands out for manageability and playfulness, making it more accessible to a wider range of drivers.
First Lap Performance:
  • All three tires show a "peak" first-lap performance, with grip and handling stabilizing as they reach optimal temperature.
Temperature Sensitivity:
  • The importance of temperature in tire performance is highlighted, with significant improvement in braking performance from the first to second braking runs, even after a warm-up procedure.
    • Key Insight: Extreme performance tires require a warm-up to achieve optimal performance.
Durability and Wear:
  • The Pirelli P Zero Trofeo R shows better durability, with minimal wear observed after testing.
  • Both Michelin and Goodyear tires exhibit signs of wear, indicating that their extreme performance may come at the cost of long-term durability.
    • Key Insight: While Pirelli shows better durability, Michelin and Goodyear may be better suited for short-duration, high-performance events.
Adam G
Adam G
Owner & Operator of GTWerks
