Wheels & Carbon Ceramic Brakes: Safe Cleaning Solutions
2025: What cleaning solutions do you use for your wheels and carbon ceramic brakes?
  • Soap & Water
    Votes: 0 0.0%
  • Total voters
    1
  • This poll will close: .
Finding the Right Wheel Cleaner: Safe for Aluminum, Magnesium, and Carbon Ceramic Brakes
For high-performance car owners, especially those with vehicles equipped with Porsche Carbon Ceramic Brakes (PCCB), cleaning the wheels presents a unique challenge. While keeping your wheels—typically made of aluminum or magnesium—clean is important for both appearance and performance, it’s equally essential to ensure that your wheel cleaner is safe for the carbon ceramic brake rotors nearby.
In this article, we’ll explore how to choose a wheel cleaner that effectively cleans aluminum and magnesium wheels without risking damage to the Porsche Carbon Ceramic Brakes. We'll also examine Ammo Brute Wheel Soap, a product that claims to be safe for use on vehicles equipped with carbon ceramic brakes, and explain why it might be an ideal choice for your cleaning needs.
Understanding Porsche Carbon Ceramic Brakes
Porsche Carbon Ceramic Brakes are designed to provide superior braking performance, with their unique combination of carbon fiber and silicon carbide (SiC). These brakes are durable and able to withstand the extreme heat generated during high-performance driving, making them ideal for track days and high-speed driving. While carbon ceramic rotors offer excellent performance, they are also more delicate than traditional steel rotors and require special attention when cleaning.
However, while carbon ceramic brakes themselves don’t require direct cleaning, the wheels surrounding them (typically made of aluminum or magnesium) need to be cleaned regularly to remove accumulated brake dust and road grime. The challenge lies in finding a wheel cleaner that is effective on the wheels yet safe for the surrounding carbon ceramic rotors.
What Makes a Wheel Cleaner Safe for Carbon Ceramic Brakes?
When selecting a wheel cleaner for a car with Porsche Carbon Ceramic Brakes, it’s important to choose a product that can clean aluminum or magnesium wheels effectively while ensuring it doesn’t damage or interfere with the carbon ceramic brake system. Below are key factors that make a wheel cleaner safe for vehicles with carbon ceramic brakes:
1. pH Balance
A wheel cleaner with a neutral to slightly alkaline pH (7–8.5) is ideal for both aluminum and magnesium wheels. This pH range is gentle enough to avoid causing damage to the wheel surface and brake rotors while still being effective at removing dirt, brake dust, and grime.
2. Non-Abrasive Formula
The cleaner should be non-abrasive, as abrasive particles or harsh chemicals could scratch or scuff the wheels or inadvertently come into contact with the carbon ceramic rotors, causing potential damage.
3. Gentle Yet Effective Surfactants
The surfactants in the cleaner should break down dirt and grime effectively without being too harsh on the brake components. These gentle ingredients help emulsify dirt and grease, making them easier to wash off without requiring aggressive scrubbing.
4. Residue-Free Formula
A good wheel cleaner should rinse off easily without leaving behind any residue that could affect the wheel finish or brake system. This ensures that no cleaning agents remain on the wheel or brake surface after washing.
Ammo Brute Wheel Soap: A Safe Solution for Vehicles with Carbon Ceramic Brakes
One product that stands out as being safe for vehicles with carbon ceramic brakes is Ammo Brute Wheel Soap. Specifically formulated for cleaning aluminum and magnesium wheels, Ammo Brute is designed to remove brake dust, grime, and road debris while being gentle on the surrounding carbon ceramic brake rotors.
Ingredients Breakdown
The formulation of Ammo Brute Wheel Soap plays a key role in its effectiveness and safety for use with carbon ceramic brakes. Here's a breakdown of the ingredients:
  • Water (7732-18-5): The base solvent used to dilute the active ingredients, making the cleaner easy to apply and spread over the wheel surface.
  • Sodium dodecylbenzenesulfonate (25155-30-0): A surfactant that helps break down oils, brake dust, and grime, ensuring that dirt is loosened and emulsified for easy removal.
  • Alcohols, C9-11, ethoxylated (68439-46-3): Another mild surfactant that works to emulsify dirt and grease, making the cleaner effective without requiring harsh scrubbing.
  • pH Range: 7–8.5 (neutral to slightly alkaline), which is safe for both the wheels and the surrounding brake components.
Why Ammo Brute Is Considered Safe for Carbon Ceramic Brakes
Ammo Brute Wheel Soap is specifically formulated to clean wheels—not the carbon ceramic rotors themselves—but its gentle, non-abrasive formula is what makes it safe for use on vehicles with carbon ceramic brakes.
  • Neutral pH: With a pH between 7 and 8.5, Ammo Brute falls within a safe range for cleaning wheels and is unlikely to cause any corrosion or damage to the carbon ceramic brake rotors. This pH range is neither too acidic nor too alkaline, reducing the risk of damaging the sensitive materials of the brake rotors.
  • Surfactants: The surfactants in Ammo Brute, such as Sodium dodecylbenzenesulfonate and Alcohols, C9-11, ethoxylated, are effective at breaking down brake dust and grime without being harsh on the surface of the carbon ceramic brake rotors. These surfactants are designed to emulsify dirt and grease, making them easier to rinse off with water.
  • Gentle Formula: Ammo Brute does not contain abrasive particles or strong chemicals that could damage the delicate surface of carbon ceramic brake rotors. This ensures that, even if some cleaner accidentally comes into contact with the rotors, it will not cause abrasions or degradation.
Best Practices for Cleaning Wheels on Vehicles with Carbon Ceramic Brakes
Even when using a safe cleaner like Ammo Brute Wheel Soap, it’s important to follow the correct cleaning process to avoid potential issues with both the wheels and carbon ceramic brake rotors. Here’s a step-by-step guide to cleaning your wheels while protecting the brake system:
1. Pre-Rinse the Wheels
Before applying any cleaner, rinse the wheels and wheel wells with water to remove any loose dirt or debris. This helps reduce the risk of scratching the wheel surface and prevents dirt from splashing onto the brake rotors.
2. Mix the Cleaner
For optimal results, follow these steps for mixing Ammo Brute:
  • Add 3 squeezes of Ammo Brute Wheel Soap into a designated wheel bucket.
  • Fill the bucket 3/4 with water to dilute the cleaner and make it easier to apply.
3. Apply the Cleaner
Apply the diluted Ammo Brute solution generously to the wheel surface, including the rim face, calipers, lug nuts, tire sidewalls, and wheel wells. Allow the solution to sit for 1–2 minutes to break down brake dust and grime.
4. Scrub the Wheel
Using a soft-bristled brush, gently scrub the wheel surface. Focus on areas with heavy brake dust buildup. For areas behind the rim, use a Plum Wheel Cleaner to clean those difficult-to-reach spots. Be sure to avoid scrubbing the carbon ceramic rotors directly.
5. Rinse Thoroughly
Once you have scrubbed the wheel, rinse it thoroughly with clean water to ensure that all the cleaner and debris are removed from the wheel surface.
6. Dry the Wheels
Use a clean microfiber towel to dry the wheels. This will help prevent water spots and ensure the wheels look pristine.
7. Repeat for Each Wheel
Repeat the process for each wheel individually, making sure that no cleaner or debris is left behind on the brake rotors.
Conclusion
Choosing the right wheel cleaner for a vehicle with Porsche Carbon Ceramic Brakes is essential to ensure that the wheels are cleaned effectively without damaging the brake system. Ammo Brute Wheel Soap is a suitable option, as it is specifically formulated to be safe for use on aluminum and magnesium wheels while being gentle enough not to affect the carbon ceramic brake rotors.
Ammo Brute’s neutral pH, mild surfactants, and gentle formula make it a safe and effective wheel cleaner. By following the recommended cleaning practices, you can keep your wheels spotless while ensuring that your carbon ceramic brakes continue to perform optimally.
As always, be sure to stay informed about the best products for your vehicle’s needs, and remember that proper maintenance, including careful wheel cleaning, will help preserve the longevity and performance of both your wheels and carbon ceramic brake system.
Adam G
Adam G
Owner & Operator of GTWerks
